Tips for Enhancing FSInn Performance (Increase FPS)
Tomado de esta web:
http://faq.apollo3.com/ljames/fsinn/vat ... ncreaseFPS
You can increase your FPS by changing some of the default settings:
** 1 ** Adjust the MP range down from the default 150 miles to a far lower figure.
(Found in the Inn Control Panel under Mulplayer)
** 2 ** Increase the Weather refresh rate from the default 5 seconds to something in minutes.
(Found in the Inn Control Panel under Weather)
** 3 ** When you have high detailed third party addon aircraft installed such as the PMDG and LevelD, FSInn might resolve other planes in the area as those high detailed models and eat up system resources displaying them. Verify to uncheck (unchecked by default) Resolve to exact model priority.
You can also check "Only use lowres Models" (unchecked by default).
These settings are located at Inn Control Panel -> Set -> Various. You can make the changes on the fly without disconnecting from VATSIM and immediately see any difference they make.
** 4 ** Turn off FSInn Graphical borders.
(Inn Control Panel -> SET -> General -> (Uncheck) FSInn Graphical borders.)
** 5 ** Exclude your high resolution Addon Planes such as PMDG and LevelD.
(Create a file named FSInn.CFG with the content in the box below. Put a copy of this fine in the root directory of your high detailed addon aircraft.)
[FSINN]
IGNORE=1
** 6 ** Run FSInn/FSCopilot on a remote machine rather than the FS machine (see FAQ question #8).
