LE83 Autogen too close from runway
petersanctus
Mensaje por petersanctus »
Greetings,
I was wondering if it would be possible for you to extend or create a Exclude Auto-gen Boundary in LE83 Mojados a little far from the end of the runways, as you can see in the pictures below the trees are to close to both R36 and R18, which makes the approach to steep. I have looked at the google earth, in Rw36 it is just like that, but in RW18 the trees are around 150 meters away from the edge of the RW.
One more thing, if you could creat a GA_Small starting position in that little concrete spot that exist in the far end of RW18 would also be interesting.
thank you.
Re: LE83 Autogen too close from runway
Hi..
Are you using FSX?
Because those trees look very weird.
Have a look at my FSX:
You should install the Spanish Photoscenery along with the custom autogen.
Anyway, it's a great opportunity to practice "short field landings" :-)
Let me have a look.
Let's try this bgl.
let me know if it works.
Regards.
mojados_LE83_AFX.zip
(1.12 KiB) Descargado 1254 veces
petersanctus
I am using P3d with orbx Europe LC... but I gree with you that these trees are not Iberia trees. I am from Portugal, and these trees looks like more norden scandinavian trees.
If anyone that have p3d could check this out I would appreciate :)
Regarding the new file... hmm I didn't see any change. I did replaced the file but nothing new.
Another thing, I can see that very close there is an area of land that has a mask similar to this one, it seems that an airport should be there and the area is very similar to this one, see the image.
petersanctus
Update:
Regarding the trees, I solved the problem, it is an option in p3d "Dynamic 3D Autogen Vegetation", it should be turn off. Now the trees looks much more normal.
Hi..
By the way..
This is me as Pilot in Command of a Cessna 172 at LE83 :-)
https://youtu.be/QJu2A7hqtos?t=1215
