Pactica que no sale
Posted: October 21, 2006, 10:48
Hola Compañeros, despues de haberme empapado un poco de todo esto y de intentar hacer algo, llamemosle practica, no me va casi nada.
Con ScenX muy bien hasta que intento compilar el XML, que os reproduzco:
=============== leav.XML ===============
00001 - <?xml version="1.0"?>
00002 - <FSData
00003 - version = "9.0"
00004 - xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
00005 - xsi:noNamespaceSchemaLocation="bglcomp.xsd" >
00006 -
00007 - <!-- File generated by SceneGenX Version 1.0 Build 61 for FS 2004 -->
00008 - <!-- Copyright RAUL -->
00009 -
00010 -
00011 -
00012 -
00013 - <Airport
00014 - region = "AVILA"
00015 - country = ""
00016 - state = ""
00017 - city = ""
00018 - name = ""
00019 - lat = "40.5748333333333"
00020 - lon = "-4.93683333333333"
00021 - alt = "2255.52"
00022 - magvar = "5.202"
00023 - ident = "LEAV">
00024 -
00025 -
00026 - <TaxiwayPoint index = "1" type = "NORMAL" orientation = "FORWARD"
00027 - lat = "40.57559055079" lon = "-4.94221933529231"/>
00028 -
00029 - <TaxiwayPoint index = "2" type = "NORMAL" orientation = "FORWARD"
00030 - lat = "40.5763210429246" lon = "-4.9436947063956"/>
00031 -
00032 - <TaxiwayPoint index = "3" type = "NORMAL" orientation = "FORWARD"
00033 - lat = "40.5755727339087" lon = "-4.94223104255482"/>
00034 -
00035 - <TaxiwayPoint index = "4" type = "NORMAL" orientation = "FORWARD"
00036 - lat = "40.574681889842" lon = "-4.94137624720108"/>
00037 -
00038 - <TaxiwayPoint index = "5" type = "NORMAL" orientation = "FORWARD"
00039 - lat = "40.5767041058733" lon = "-4.93721972686145"/>
00040 -
00041 - <TaxiwayPoint index = "6" type = "NORMAL" orientation = "FORWARD"
00042 - lat = "40.5757152689593" lon = "-4.93809787528092"/>
00043 -
00044 - <TaxiwayPoint index = "7" type = "NORMAL" orientation = "FORWARD"
00045 - lat = "40.5756529098747" lon = "-4.94607150617334"/>
00046 -
00047 - <TaxiwayPoint index = "8" type = "NORMAL" orientation = "FORWARD"
00048 - lat = "40.576499211738" lon = "-4.93476086530226"/>
00049 -
00050 - <TaxiwayPoint index = "9" type = "NORMAL" orientation = "FORWARD"
00051 - lat = "40.5768822746866" lon = "-4.93458521954644"/>
00052 -
00053 - <TaxiwayPoint index = "10" type = "NORMAL" orientation = "FORWARD"
00054 - lat = "40.5765081201786" lon = "-4.93474915616581"/>
00055 -
00056 - <TaxiwayPoint index = "11" type = "NORMAL" orientation = "FORWARD"
00057 - lat = "40.5761072403486" lon = "-4.94630574471361"/>
00058 -
00059 - <TaxiwayPoint index = "12" type = "NORMAL" orientation = "FORWARD"
00060 - lat = "40.5756796351967" lon = "-4.94602467500151"/>
00061 -
00062 - <TaxiwayParking index = "1" lat = "40.5739319611095" lon = "-4.94122398695776"
00063 - heading = "0.0" radius = "50.0" type = "GATE_SMALL"
00064 - name = "GATE" number = "2" pushBack = "NONE"/>
00065 -
00066 - <TaxiwayPath type = "TAXI" start = "1" end = "2" width = "10.0"
00067 - weightLimit = "500000" surface = "ASPHALT"
00068 - centerLine = "TRUE" centerLineLighted = "TRUE"
00069 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00070 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00071 -
00072 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00073 - weightLimit = "500000" surface = "ASPHALT"
00074 - centerLine = "TRUE" centerLineLighted = "TRUE"
00075 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00076 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00077 -
00078 - <TaxiwayPath type = "TAXI" start = "1" end = "1" width = "10.0"
00079 - weightLimit = "500000" surface = "ASPHALT"
00080 - centerLine = "TRUE" centerLineLighted = "TRUE"
00081 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00082 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00083 -
00084 - <TaxiwayPath type = "TAXI" start = "2" end = "2" width = "10.0"
00085 - weightLimit = "500000" surface = "ASPHALT"
00086 - centerLine = "TRUE" centerLineLighted = "TRUE"
00087 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00088 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00089 -
00090 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00091 - weightLimit = "500000" surface = "ASPHALT"
00092 - centerLine = "TRUE" centerLineLighted = "TRUE"
00093 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00094 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00095 -
00096 - <TaxiwayPath type = "TAXI" start = "1" end = "0" width = "10.0"
00097 - weightLimit = "500000" surface = "ASPHALT"
00098 - centerLine = "TRUE" centerLineLighted = "TRUE"
00099 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00100 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00101 -
00102 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00103 - weightLimit = "500000" surface = "ASPHALT"
00104 - centerLine = "TRUE" centerLineLighted = "TRUE"
00105 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00106 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00107 -
00108 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00109 - weightLimit = "500000" surface = "ASPHALT"
00110 - centerLine = "TRUE" centerLineLighted = "TRUE"
00111 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00112 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00113 -
00114 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00115 - weightLimit = "500000" surface = "ASPHALT"
00116 - centerLine = "TRUE" centerLineLighted = "TRUE"
00117 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00118 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00119 -
00120 - <TaxiwayPath type = "TAXI" start = "1" end = "0" width = "10.0"
00121 - weightLimit = "500000" surface = "ASPHALT"
00122 - centerLine = "TRUE" centerLineLighted = "TRUE"
00123 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00124 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00125 -
00126 - <TaxiwayPath type = "TAXI" start = "0" end = "0" width = "10.0"
00127 - weightLimit = "500000" surface = "ASPHALT"
00128 - centerLine = "TRUE" centerLineLighted = "TRUE"
00129 - leftEdge = "SOLID" leftEdgeLighted = "TRUE"
00130 - rightEdge = "SOLID" rightEdgeLighted = "TRUE" name = "0"/>
00131 -
00132 - <TaxiwayPath type = "TAXI" start = "3" end = "4" width = "10.0"
00133 - weightLimit = "500000" surface = "ASPHALT"
00134 - centerLine = "FALSE" centerLineLighted = "FALSE"
00135 - leftEdge = "DASHED" leftEdgeLighted = "TRUE"
00136 - rightEdge = "DASHED" rightEdgeLighted = "TRUE" name = "0"/>
00137 -
00138 - <TaxiwayPath type = "TAXI" start = "5" end = "6" width = "10.0"
00139 - weightLimit = "500000" surface = "ASPHALT"
00140 - centerLine = "FALSE" centerLineLighted = "FALSE"
00141 - leftEdge = "DASHED" leftEdgeLighted = "TRUE"
00142 - rightEdge = "DASHED" rightEdgeLighted = "TRUE" name = "1"/>
00143 -
00144 - <TaxiwayPath type = "TAXI" start = "7" end = "8" width = "10.0"
00145 - weightLimit = "500000" surface = "ASPHALT"
00146 - centerLine = "FALSE" centerLineLighted = "FALSE"
00147 - leftEdge = "DASHED" leftEdgeLighted = "TRUE"
00148 - rightEdge = "DASHED" rightEdgeLighted = "TRUE" name = "2"/>
00149 -
00150 - <TaxiwayPath type = "TAXI" start = "9" end = "10" width = "10.0"
00151 - weightLimit = "500000" surface = "ASPHALT"
00152 - centerLine = "FALSE" centerLineLighted = "FALSE"
00153 - leftEdge = "DASHED" leftEdgeLighted = "TRUE"
00154 - rightEdge = "DASHED" rightEdgeLighted = "TRUE" name = "3"/>
00155 -
00156 - <TaxiwayPath type = "TAXI" start = "11" end = "12" width = "10.0"
00157 - weightLimit = "500000" surface = "ASPHALT"
00158 - centerLine = "FALSE" centerLineLighted = "FALSE"
00159 - leftEdge = "DASHED" leftEdgeLighted = "TRUE"
00160 - rightEdge = "DASHED" rightEdgeLighted = "TRUE" name = "4"/>
00161 -
00162 - <TaxiName index="0" name="A" />
00163 -
00164 - <TaxiName index="1" name="B" />
00165 -
00166 - <TaxiName index="2" name="C" />
00167 -
00168 - <TaxiName index="3" name="G" />
00169 -
00170 - <TaxiName index="4" name="H" />
00171 -
00172 - <Runway
00173 - lat = "40.5767230025656" lon = "-4.94049975597028" alt = "2255.52"
00174 - surface = "ASPHALT" heading = "84.798" length = "1000.0" width = "50.0" number = "09" designator = "NONE"
00175 - patternAltitude = "243.84" primaryTakeoff = "TRUE" primaryLanding = "TRUE" primaryPattern = "LEFT"
00176 - secondaryTakeoff = "TRUE" secondaryLanding = "TRUE" secondaryPattern = "LEFT">
00177 - <Markings
00178 - edges = "TRUE"
00179 - threshold = "TRUE"
00180 - fixedDistance = "TRUE"
00181 - touchdown = "TRUE"
00182 - dashes = "TRUE"
00183 - ident = "TRUE"
00184 - precision = "FALSE"
00185 - edgePavement = "FALSE"
00186 - singleEnd = "FALSE"
00187 - primaryClosed = "FALSE"
00188 - secondaryClosed = "FALSE"
00189 - primaryStol = "FALSE"
00190 - secondaryStol = "FALSE"/>
00191 - <Lights center = "MEDIUM" edge = "MEDIUM" centerRed = "FALSE"/>
00192 - <ApproachLights
00193 - end = "PRIMARY"
00194 - system = "NONE"
00195 - strobes = "0"
00196 - reil = "TRUE"
00197 - touchdown = "TRUE"
00198 - endLights = "TRUE"/>
00199 - <ApproachLights
00200 - end = "SECONDARY"
00201 - system = "NONE"
00202 - strobes = "0"
00203 - reil = "FALSE"
00204 - touchdown = "FALSE"
00205 - endLights = "TRUE"/>
00206 - <Ils
00207 - lat = "40.577109934837"
00208 - lon = "-4.93490549350683"
00209 - alt = "2255.52"
00210 - heading = "84.798"
00211 - frequency = "110.0"
00212 - end = "PRIMARY"
00213 - range = "0.0"
00214 - magvar = "5.202"
00215 - ident = "ILS/DME"
00216 - width = "0.0"
00217 - name = "ILS/DME Runway 09"
00218 - backCourse = "FALSE">
00219 - <GlideSlope
00220 - lat = "40.5764170561185"
00221 - lon = "-4.94491125336439"
00222 - alt = "2255.52"
00223 - pitch = "0.0"
00224 - range = "0.0"/>
00225 - <Dme
00226 - lat = "40.5764170561185"
00227 - lon = "-4.94491125336439"
00228 - alt = "2255.52"
00229 - range = "0.0"/>
00230 - </Ils>
00231 - </Runway>
00232 -
00233 - <Start
00234 - type = "RUNWAY"
00235 - lat = "40.5761695994333"
00236 - lon = "-4.94375323487055"
00237 - alt = "0.0"
00238 - heading = "0.0"
00239 - number = "NORTH"
00240 - designator = "NONE"/>
00241 -
00242 - <Aprons>
00243 -
00244 - <Apron surface = "BITUMINOUS" drawSurface = "TRUE" drawDetail = "TRUE">
00245 - <Vertex lat = "40.5759420292672" lon = "-4.93649803698355"/>
00246 - <Vertex lat = "40.57412065808" lon = "-4.93707388861032"/>
00247 - <Vertex lat = "40.575483649502" lon = "-4.93961893503405"/>
00248 - </Apron>
00249 -
00250 - <Apron surface = "BITUMINOUS" drawSurface = "TRUE" drawDetail = "TRUE">
00251 - <Vertex lat = "40.5754625931877" lon = "-4.93962957840967"/>
00252 - <Vertex lat = "40.5741141792141" lon = "-4.93706963097191"/>
00253 - <Vertex lat = "40.5727058357305" lon = "-4.94041710541968"/>
00254 - </Apron>
00255 -
00256 - <Apron surface = "ASPHALT" drawSurface = "TRUE" drawDetail = "TRUE">
00257 - <Vertex lat = "40.5726159360666" lon = "-4.94045648975855"/>
00258 - <Vertex lat = "40.575483649502" lon = "-4.9396380946942"/>
00259 - <Vertex lat = "40.574204073479" lon = "-4.94230756931522"/>
00260 - </Apron>
00261 -
00262 - </Aprons>
00263 -
00264 - <ApronEdgeLights>
00265 -
00266 -
00267 -
00268 -
00269 -
00270 - </ApronEdgeLights>
00271 -
00272 - </Airport>
00273 -
00274 - <Marker lat = "40.5739694662818" lon = "-4.98024487303013" alt = "2255.52"
00275 - type = "OUTER" ident = "OM" heading = "84.798" region = "AA"/>
00276 -
00277 - <Vor
00278 - lat = "40.57732769672" lon = "-4.94056850558682" alt = "1127.76"
00279 - type = "HIGH" frequency = "108.0" magvar = "5.202"
00280 - region = "AA" ident = "AVL" name = "AVILA"
00281 - nav = "TRUE" dmeOnly = "FALSE" dme = "TRUE">
00282 - <Dme lat = "40.57732769672" lon = "-4.94056850558682" alt = "1127.76" range = "20000.0"/>
00283 - <VisualModel
00284 - heading = "0.0"
00285 - imageComplexity = "SPARSE"
00286 - name = "3a5affe143e95cb6df00d3b5786eb8c3">
00287 - </VisualModel>
00288 - </Vor>
00289 -
00290 -
00291 -
00292 -
00293 - </FSData>
00294 -
Cuando compilo, y tengo el BGL instalado, me sale:
C:\Archivos de programa\FS2004SDK\BGLCOMP_SDK>bglcomp.exe leav.xml
Parsing document: leav.xml
ERROR C2034: XML Parse Fatal Error (line, column, error)
ERROR: 1, 1, Incorrect document syntax.
ERROR C2470: Unrecoverable error parsing XML!
ERROR C2006: Parse failed (0x80004005)
ERROR C2003: Failed to process file: leav.xml
y de hay no paso. Lo he revisado, pero mi desconocimiento noo da para mas, jajjaa.
Y al hilo otra pregunta; Genero un auropuerto con AFCAD y estupendo, pero ¿ Donde genera el .XML?
00002 - <FSData
00006 -
00009 -
00010 -
00011 -
00012 -
00013 - <Airport
00016 - state = ""
00017 - city = ""
00018 - name = ""
00024 -
00025 -
00028 -
00031 -
00034 -
00037 -
00040 -
00043 -
00046 -
00049 -
00052 -
00055 -
00058 -
00061 -
00065 -
00071 -
00077 -
00083 -
00089 -
00095 -
00101 -
00107 -
00113 -
00119 -
00125 -
00131 -
00137 -
00143 -
00149 -
00155 -
00161 -
00163 -
00165 -
00167 -
00169 -
00171 -
00172 - <Runway
00177 - <Markings
00206 - <Ils
00219 - <GlideSlope
00225 - <Dme
00230 - </Ils>
00231 - </Runway>
00232 -
00233 - <Start
00237 - alt = "0.0"
00241 -
00242 - <Aprons>
00243 -
00248 - </Apron>
00249 -
00254 - </Apron>
00255 -
00260 - </Apron>
00261 -
00262 - </Aprons>
00263 -
00265 -
00266 -
00267 -
00268 -
00269 -
00271 -
00272 - </Airport>
00273 -
00276 -
00277 - <Vor
00288 - </Vor>
00289 -
00290 -
00291 -
00292 -
00293 - </FSData>
00294 -
