HELP - Lights question
Autogen for Spain photoscenery
Forum rules
NoHablaEspanol
Post by NoHablaEspanol »
Buenos dias,
I am not a native Spaniard, so I hope it's ok if I write in English.
I've recently downloaded the Hispania Freeware Photoscenery, which is amazing. However, I seem to have problems with the autogen. (I ONLY use the ISLAS CANARIAS scenery, nothing else)
In the PDF-manual (from the MEGA-website) the writer states there should be lights, gas stations etc, but I only seem to have houses on the mesh. How to fix? :(
Also, during night-time there is no lights/traffic lights. Is this normal, or am I doing something wrong?
I have my folders in the following way:
PHOTOSCENERY SPAIN -> 17 ISLAS CANARIAS -> SCENERY + TEXTURES
Gracias for your help.
Re: HELP - Lights question
Hi..
I think is a bad translation. It should say "street lamps" or "street lights".
They are by the small roads (between towns) and I am not sure whether they are lit or not...
Check it again and let us know.
By the way, I will move this post to the "FSX España - Autogen para escenarios ortofotográficos" forum.
Regards.
NoHablaEspanol
Hello again,
I tried it again but there are no lights. The buildings are lit up (a very tiny bit), but no street lights or so. Nevertheless, I checked around on the forum and saw a topic in which an addon (Night Enviro Spain) was talked about. I have now installed that and that works just fine with the Hispania freeware, so I believe all is ok now.
Thanks for the reply!
Hi again.
I think you did not understand... There are streetlamps, but not lit.
See the snapshot:
Well, they are slightly lit but they can not be seen from the plane:
By the way, did you install the Library?
viewtopic.php?f=53&t=2973
Regards.
NoHablaEspanol
Hello,
I understand what you mean now. I did not mean the same thing; I was looking for more lookalike-scenery with lights like ORBX or UTX Europe or so. But with the Night Enviroment X Spain it is fine now. :)
I have done so now, and I do see pylons - if that is what you meant?
NoHablaEspanol
Also, another question.
I don't have any AI car traffic, is this normal or am I missing something out?
