Aquí esta el XML para la nueva pista de Sanguesa.
La altura en casi todo el recorrido de la pista esta bastante superior que el terreno excepto en un punto del primer tercio de la rwy 19 que esta a ras y he tomado como referencia. Podría quedar más centrada y orientada sobre el terreno con unos 16 grados de dirección de pista, pero eso nos daría pista 20 y 02.
<?xml version="1.0"?>
<FSData
version = "9.0"
xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance'
xsi:noNamespaceSchemaLocation="bglcomp.xsd" >
<!-- File generated by SceneGenX Version 1.0 Build 61 for FS 2004 -->
<!-- Copyright Miguel Jose Urroz -->
<Airport
region = "Navarra"
country = "Spain"
state = ""
city = "Sanguesa"
name = "Los Burales"
lat = "42.56693143195"
lon = "-1.28930375235"
alt = "397.0"
magvar = "0.0"
ident = "LESG">
<Runway
lat = "42.5680916073617" lon = "-1.28709751803801" alt = "397.0"
surface = "GRAVEL" heading = "14.0" length = "1056.0" width = "50.0" number = "01" designator = "NONE"
patternAltitude = "243.84" primaryTakeoff = "TRUE" primaryLanding = "TRUE" primaryPattern = "LEFT"
secondaryTakeoff = "TRUE" secondaryLanding = "TRUE" secondaryPattern = "LEFT">
<Markings
edges = "FALSE"
threshold = "FALSE"
fixedDistance = "FALSE"
touchdown = "FALSE"
dashes = "FALSE"
ident = "TRUE"
precision = "FALSE"
edgePavement = "FALSE"
singleEnd = "FALSE"
primaryClosed = "FALSE"
secondaryClosed = "FALSE"
primaryStol = "FALSE"
secondaryStol = "FALSE"/>
<Lights center = "NONE" edge = "NONE" centerRed = "FALSE"/>
<ApproachLights
end = "PRIMARY"
system = "NONE"
strobes = "0"
reil = "FALSE"
touchdown = "FALSE"
endLights = "TRUE"/>
<ApproachLights
end = "SECONDARY"
system = "NONE"
strobes = "0"
reil = "FALSE"
touchdown = "FALSE"
<RunwayStart
type = "RUNWAY"
lat = "42.5636125359727"
lon = "-1.28861161485556"
alt = "397.0"
heading = "14.0"
end = "PRIMARY"/>
<RunwayStart
type = "RUNWAY"
lat = "42.5725706786848"
lon = "-1.28558320346195"
alt = "397.0"
heading = "194.0"
end = "SECONDARY"/>
</Runway>
</Airport>
</FSData>
PISTA COOREGIDA EN SANGUESA 19 - 01
nueva pista 1-19
Buen trabajo, Miguel. Con ligerísimos ajustes para hacer coincidir la pista con el ortofoto, este es el escenario de momento:
http://personal.telefonica.terra.es/web ... mentos.htm
Algunas cosillas en el XML
- he puesto a Airport las mismas coordenadas del centro de la pista. De esta forma, LESG aparecerá referenciado en ese punto en todas las aplicaciones.
- he mantenido la altitud que das en 397 y he hecho un flatting a 396,9 siguiendo un poco el contorno de la pista y zona de edificios. El flatting, siempre convexo.
- el tipo de pista ya a GRASS. En la pista real se distingue menos el centro.
- he quitado las luces de aproximación. Esta pista va a pelo.
Bueno, pues si se plantea alguna duda, procuraremos aclararla entre Miguel y yo.
Janu AHS6585
